Volvo 740 ('90) - Odd warning light!
Old Jul 21, 2011 | 06:46 AM
S.A.C. Martin's Avatar
Default Volvo 740 ('90) - Odd warning light!
My apologies gents for the lack of introduction, however I have a problem with my car which is due to drive to Gatwick and back tonight at about one in the morning, so you can appreciate I am desperate to sort it sooner, rather than later!
A strange warning light has popped up on the dashboard, and I have no idea what it means. It's my parents car, and I am using it to pick them up from the airport. The light comes on when the engine is turned on, and stays on.
This is the light in question:
It's the light with the two semi circular things with dashes coming off them. My first thought was that it was the side lights, but having checked all round the car, the circuits, and the bulbs, it seems to be fine in that respect.
I rang my local Volvo garage who informed me they wouldn't be able to look at it until tomorrow. They are normally very very good which is rather frustrating, given the urgency. I don't want to break down on the M25 tonight, after all...!
My thanks in advance for any replies which are forthcoming, I thoroughly enjoy driving the 740GL, but as you can appreciate, I want piece of mind for my late night drive to the airport tonight!
Old Jul 21, 2011 | 09:20 AM
lev's Avatar
lev
I don't know, must be something that we don't have in the US, but it has to do with lights. I'd worry more about that other light in your picture, the one that looks like the thing the Magic Genie comes out of, that means that you have an oil problem-definitely more serious.
Old Jul 21, 2011 | 12:28 PM
Koriflame's Avatar
My 740 has a similar light that comes on when the headlights are on (& used to when the brake pedal was pressed then go off when it was released) I figured its normal since everything works.
Old Jul 21, 2011 | 07:40 PM
Volvohayden's Avatar
Im with lev if the lights are having an issue but they are still working I wouldnt worry as much, but if you have an oil issue that could put a damper on your parade.
Old Jul 21, 2011 | 08:08 PM
lev's Avatar
lev
On second thought, I am pretty sure that the light in question is nothing more than to show that the lights are ON. I have seen similar on other cars...
Old Jul 21, 2011 | 09:26 PM
I believe that might be a bulb out indicator, those sometimes give false readings, based on dirty bulb contacts, or old bulbs. on my 92 740 US model, its in that same position (2 over from the oil pressure light) and is yellow but has a different graphic (picture of a round bulb with lines radiating from it and a filament in the middle).
Old Jul 21, 2011 | 11:52 PM
Titan Joe's Avatar
That's the same symbol for the running lights position on my 740's main light ****. I think Lev is onto it, but my car does not have that since it is a US spec car. Your's being a euro spec car is probably a bit different, but I would seem that this would be no problem. Just flip around your light **** and see what happens. Also, here in the US our running light can be on without the key in the ignition. It may be just a warning so you don't leave them on.
another740owner
Jul 12, 2015 10:40 PM
mightyjak
Aug 12, 2011 06:46 AM
mjsparky363
Oct 20, 2008 08:33 AM
lotusing
Oct 11, 2006 12:42 AM
Muskoka
Mar 20, 2006 10:04 PM
