what to check
Old Apr 21, 2021 | 05:06 PM
bigarms24's Avatar
Default what to check
I have a 88 240 dl and lately itll start right away but then ill be in the gym for 2 hours come back and go to start it and it sounds like its tired and kinda wants to start the battery and alternator are working like they should I did do a complete tune up a year ago any suggestions would be helpful
Old Apr 21, 2021 | 06:25 PM
silvermine's Avatar
hows the weather in kingman bro.. wicked hot and dry.. look to the battery.....
Old Apr 21, 2021 | 07:32 PM
bigarms24's Avatar
accutally its been 64-75 and super windy
Old Apr 21, 2021 | 07:46 PM
lev's Avatar
lev
Start with battery. You need volts and amps, many ignore the latter. Better make sure before you go into more expensive parts.
Old Apr 21, 2021 | 08:49 PM
bigarms24's Avatar
ok Ill go get it tested tomorrow thanks i do know i replaced the battery in 2016 ish
Old Apr 22, 2021 | 11:51 AM
5 years for a battery in extreme climates (cold or hot) means its probably due. The other thing to do is to inspect the cables and clean the terminals.
Old Apr 22, 2021 | 02:45 PM
bigarms24's Avatar
I just replaced the battery 25 mins ago and terminals look good so hopefully that fixes it
Old Apr 23, 2021 | 10:51 AM
silvermine's Avatar
i had the same thing happen, thought the battery was good but better testing equipment than i had at hand proved
otherwise....
hope it cures your issue
Old Apr 23, 2021 | 01:51 PM
bigarms24's Avatar
thanks after i found the reciept for the battery was from 2014 so i got a new one yesterday am curious how long do motor mounts last? I replaced both in 2016 and noticed that my engine is shaking on the drivers side
Old Apr 23, 2021 | 07:30 PM
lev's Avatar
lev
Many last 200k... OEM. Replacement quality, who knows? But the 240 ones are cheap and not hard to swap--get a good quality one, first make sure it's bad: jack up the engine slightly to see if vibration goes away or look under the car for chassis-engine contact which would be caused by a collapsed mount.
Old Apr 23, 2021 | 10:06 PM
bigarms24's Avatar
I definately will thank you very much
Old Apr 24, 2021 | 11:26 AM
silvermine's Avatar
the original motor mounts in mine were toast at about 181k miles..
shavalena
Jan 7, 2017 02:43 PM
sarahshufelt
May 24, 2015 08:42 PM
howardc
Mar 14, 2013 08:38 PM
AnEskimo
May 8, 2010 09:49 AM
shane12
Feb 14, 2006 08:51 PM
