will not start
Old Sep 22, 2009 | 05:54 PM
mystery240's Avatar
Default will not start
hello im new here and im having a problem with my 85 244 gl and i was letting my car run in my driveway and out of no where my car stalled and from then on it is unable to turn over again . when i try to start it it will crank like it want to start like it is getting no fuel . do you think there is a clog in my fuel line? any suggestions will help im a novice mechanic at best . thank you
Old Sep 22, 2009 | 06:50 PM
TURBO 245's Avatar
Take a short piece of wire or a paper clip and jump fuse #4 to fuse #6.If it starts your fuel pump relay is bad,also check the 20 amp fuse located on the inner fender between the battery and headlight relay.These will corrode and cause a no start issue.
Dan
Old Sep 22, 2009 | 09:00 PM
Fernando Cabezas's Avatar
Default Test
In order to define from where come your problem you can open the intake hose and to drop some fuel near the carburator or injection system while you try to start the engine, so you will test if it is lack of fuel or spark.
Old Sep 23, 2009 | 01:41 AM
mystery240's Avatar
im pretty sure i got spark
Old Sep 28, 2009 | 08:22 PM
holobox's Avatar
fuel pump relay - tucked under the glove box - give it a nice whack while your cranking. Can't tell you how many of these I've replaced over the years with my three 240s.
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
