WINDOW WON"T ROLL UP!!!
Old Sep 27, 2008 | 09:54 PM
Gravik's Avatar
Default WINDOW WON"T ROLL UP!!!
Alright, so I have an '82 240 Turbo wagon. I Rolled all my windows down earlieir then rolled them up but the ffront passenger side window would not roll up. I tried turning the car off then back on, but nothing changed.
ANy suggestions?
Old Sep 27, 2008 | 10:41 PM
Default RE: WINDOW WON"T ROLL UP!!!
Maybe the window regulator is bad.
Power or manual windows?
The only real way to find out for sure is to open the door up and check.
Old Sep 27, 2008 | 10:54 PM
Gravik's Avatar
Power.
and alight. I'll try that
Old Sep 30, 2008 | 09:22 AM
k's Avatar
k
Hi,
I had the same problem on our '93 940...but if you're lucky like me, it won't be the regulator- they're expensive.
Mine started with 1 window not rolling up...eventually none would roll up. The problem was in the switches...one of them had gotten dirty and dislodged (internally there are a few metal strips and ball bearings) and to the circuit was not operating properly. I took an afternoon and cleaned all of the switches and now everything is perfect...
It will take some time, start w/ the problem window (you may only need to do that one, I did all of mine on a "while I'm at it" basis) and take out the switch, pry it open, clean and reassemble. careful not to lose any parts or break too much of the plastic housing (which is bound to happen to some degree)
Good luck!
Old Sep 30, 2008 | 11:16 AM
fredbyte's Avatar
Visit www.stepbystepvolvo.com for info on replacing window switches.
Old Oct 31, 2008 | 01:11 AM
Beardog's Avatar
Check the fuse first. then check the switch. then dig into the door. though it is easy to remove. there are at least three clips on the bottom of the window to remove the siding. dont forget to remove the lock cap. also the speaker grill should slide to the front of the vehicle to remove.
dman777
Oct 30, 2016 09:43 PM
fd6515
1998-2000 model year V70
Apr 30, 2014 01:03 PM
87 740 turbo wagon
Feb 17, 2014 08:29 PM
alex57
Sep 28, 2010 06:48 PM
kottre
Jul 25, 2005 09:37 PM
