Intermittent Staring Probleb
Old Oct 30, 2008 | 12:27 PM
vineyardsailor's Avatar
Default Intermittent Staring Probleb
I have a 94 940T and it fails to start intermittently. I suspect the problem is fuel related. Any hints on how to trouble shot which of the normal suspects is at fault - fuel pump, relay, etc
Old Oct 30, 2008 | 06:34 PM
fredbyte's Avatar
Default RE: Intermittent Staring Probleb
Intermittent problems are hard to diagnose. Once the engine is dead, you have constant conditions. Go to www.stepbystepvolvo.com for a free diagnostic guide for 740 no-starts. 940 engine is similar.
Old Oct 31, 2008 | 08:58 AM
wojeepster's Avatar
pull the hose off the fuel pressure regulator and see if diapharam has hole in it (fuel should not be in vacuum line) this will cause starting problems when warm. some other suspects are fuel pump relay, electrical part of ignition switch, intank pre pump (if problem occurs at less than 1/2 tank of gas) or main pump if tapping on main pump makes car start.
majorcode
Nov 8, 2012 05:19 AM
rmcmighty
Dec 4, 2007 02:32 PM
skunkworks
Jun 22, 2004 01:48 AM
TheVolvoMan
Apr 20, 2004 11:05 PM
