wiper motor
Old Jan 5, 2007 | 09:24 AM
loserking86's Avatar
Default wiper motor
bought new wiper motor for my 240, hooked it up...nothing happens..checked the fuse and it is fine...i know the old motor was shot..there was still electricity going to it before b/c i could atleast have fluid come out when i did the wipe wash...now i get nothing...any thoughts other than a bad part?
Old Jan 5, 2007 | 11:52 AM
JetTech's Avatar
Default RE: wiper motor
I don't have the eletrical schematic in front of me loserking butI would be surprised if the pump and motor ran off the same curcuit. Have you checked to see if you have power at the motor?
Old Jan 5, 2007 | 04:05 PM
billofdurham's Avatar
Strangely enough the pump and motor do both work off fuse #2. If the fuse is indeed OK you must have a bad connection somewhere. As JetTech suggests check for 12v at the motor then work back from there.
Old Mar 15, 2007 | 04:25 PM
triumph7's Avatar
Greetings ..Some 249's the moter is grounded by itslef ..some need the ground wire..my 86 motor died replaced with one out of a 89 that needed a` ground wire..
KS70T5M
May 10, 2010 07:52 PM
mpoulin2002
Nov 3, 2008 01:59 PM
Psaboic
Apr 29, 2007 02:59 PM
Ward850T
Apr 25, 2007 09:50 PM
Cape Islander
Feb 26, 2004 11:13 PM
