worn screws
Old Jan 23, 2019 | 10:18 AM
corsso's Avatar
Default worn screws
Can worn Volvo Driveline (driveshaft) Flange Bolts affect or cause vibrations on driveline (driveshaft) (1995 940 non turbo sedan)
Old Jan 23, 2019 | 10:51 AM
jagtoes's Avatar
Only if they are not tight.
Old Jan 23, 2019 | 11:08 AM
corsso's Avatar
Thanks jagtoes!
Old Jan 24, 2019 | 07:56 PM
commonest cause of driveshaft vibration is the center bearing and its carrier bushing.
I would probably replace those driveshaft flange bolts if and only if had to disconnect the driveshaft, for instance to pull the transmission, or to R&R the center bearing. if you have to disconnect the driveshaft spline be absolutely sure to mark both sides of the spline so you reassemble it in th exact same orientation, as the assembly was balanced at the factory.
Old Jan 28, 2019 | 05:10 AM
corsso's Avatar
Smile
Thanks pierce!
Old Feb 2, 2019 | 10:04 AM
corsso's Avatar
Pierce, I just had drive train (drive shaft) replaced on my 1995 Volvo 940 2.3 sedan/non turbo. The replacement part is a used item and I used the bolts that were on the replaced or original shaft. Is there an urgent need to replace the bolts with new ones. What is the risk, thanks!
Old Feb 2, 2019 | 02:51 PM
as long as they were in OK shape and not stretched or worn, or heavily corroded, they are probably just fine. I just like using new hardware out as a precaution thing.
corsso
Jan 23, 2019 01:02 PM
BlueStreak91
Dec 27, 2018 07:49 AM
cichy1012
Oct 10, 2011 05:12 PM
Bradhobbs
Mar 5, 2009 12:33 AM
davemoffat
Apr 13, 2008 11:19 AM
