1995 volvo 960
Old Oct 19, 2014 | 04:04 AM
FFEJ's Avatar
Default 1995 volvo 960
Hey I just bought my first volvo and after driving it for 135km it started misfiring and the check engine light came on after turning a corner into a parking lot and giving it some gas to make the turn. After turning off the car and starting it again the engine was running normally but the check engine light was still on. The car has 92,000km and looks like new the timing belt, water pump, brake booster where changed 3 months before I bought the car. I had it inspected buy a mechanic before buying it and they said it was good. The concerns I had where the engine making a ticking noise witch they said was from using cheap gas and not premium and a hissing noise coming from the drivers side while pressing the gas they didn't say anything about it.
Old Oct 26, 2014 | 05:27 PM
Hi and welcome to the forum.
Sounds like you did NOT have a Volvo shop check the car out for you. Chances are, you have a vacuum or PCV system issue with the noise. Clicking is likely nothing if it's the fuel injectors (usually a little noisy), hopefully it's not a noisy lifter (louder).
Old Oct 27, 2014 | 06:29 AM
Welcome to the forum
Is the ticking noise something you have all the time or only for a little while after starting up ?? If it's something happening when first starting and you have a "Fram" oil filter on it good reason to change at least the filter. For some reason Frams can be the cause of lifter ticking on start up.
If you think it is the fuel injectors you can always try a bottle of Lucas injector cleaner just for maintenance and see if it helps quiet them down. The single server bottles are smaller. The picture is a quart, it's a lot cheaper to buy it that way (or gallon) if you have a couple vehicles.
Old Dec 6, 2014 | 01:15 AM
FFEJ's Avatar
Thanks for the help I had a vacuum leak and got it fixed and now its running perfect plus my gas mileage has gone up I was getting about 400km a tank now I'm getting 650km.
navybluex2
Aug 29, 2010 01:45 PM
ishaqalphonse
Aug 28, 2010 02:52 PM
ecker
May 31, 2010 04:40 AM
RFolmar19
Aug 5, 2009 10:00 PM
EricB
Suspension
Jun 17, 2007 07:16 AM
