960 slight intermittent hestitaion
Old Dec 28, 2012 | 11:11 AM
kotomek's Avatar
Default 960 slight intermittent hestitaion
I am second owner of 1993 Volvo 960 with 135 K mileage on it. I noticed recently while driving that from time to time the engine (or transmission) will slightly hesitate. Does not change gears or shows RPM going up or down, but feel like for a split of a second is badly starving for a gas. The dashboard works fine and I am not noticing any electrical issues. When the car is in Park the engine works fine. The idle sounds also perfect. No codes displayed. Always starts and never stopped working. I am not sure if that is not only my imagination, but looks like the problem is more visible while going uphill than on a flat road. Any ideas where to start?
Old Dec 28, 2012 | 11:34 AM
Is the CEL on?
Old Dec 29, 2012 | 02:30 AM
kotomek's Avatar
No CEL light on at this moment (and I am driving for at least 2 months), but while ago I had code 241 - EGR Flow too low. Clear the codes while I was doing routine maintenance and the code never show up again
Old Dec 29, 2012 | 07:49 AM
If you have no CEL my guess would be that you have a fuel flow problem. Most other issues make the CEL come on.
Try running 91+ octane for the next 2 tanks and see if that makes a difference.
Old Dec 30, 2012 | 12:19 AM
kotomek's Avatar
Thanks, Will try
thullz
Mar 5, 2008 07:11 PM
kennys s40
Oct 23, 2006 10:22 PM
John124
Oct 6, 2006 03:41 PM
blaackone32
Apr 4, 2005 09:40 PM
