I have a V90 3.0 -98 that is slow on accelerating othervise it runs fine. I have tried to disconnect the MAF while running and didn't notice any difference at idle.
The 0-60 time (11,5 sec) is the same with and without MAF connected.
The flow at idle seems okey at 14 kg/h. At full throttle the maximum flow i get registered is 408 kg/h. Shouldn't it reach higher numbers? I also think it is very flat/stable at 408 kg/h, shouldn't it change a bit at least.
In the graph below is a full throttle run, the dip is when changing gear, after the dip its about 4000 rpm to 6000 rpm.
Anyone had a MAF that was working at lower flows but was maxed out/defective before it should at higher flows?
Well, I just swap the MAFS with a good known one. There is no good way to test and as much as I envy your expertise with measuring things, I have never heard of a successful attempt. Still, "same with MAFS connected as with it disconnected", that doesn't seem right...
