Need Help 760 Possible Transmission Problems?
Old Jul 26, 2021 | 07:10 PM
jim1234's Avatar
Default Need Help 760 Possible Transmission Problems?
1990 760 Turbo Wagon. Was driving along and car felt like it wanted to stall. Needed extra gas to rev it to get it home. Felt almost like it was the MAF and was starting to go into in limp mode. Very groggy. I thought it was the MAF so I cleaned it and reset the idle, I also cleaned the throttle body. Took it for a drive the next morning and when I started it and put it in reverse there was a whirring sound that lasted a few seconds. It drove very slow and wouldn't drive over 10mph. When I got back there was a pool of clear viscous liquid below where the transmission and engine meet but slightly towards the right side. The car starts and idles fine but does not drive faster than 5 mph. Would it be rear main seal? transmission? Please help and thank you.
Old Jul 26, 2021 | 07:37 PM
What is your transmission fluid level?
Old Jul 27, 2021 | 05:20 PM
lev's Avatar
lev
You have a transmission fluid leak. Once you fill it up it will drive fine provided you haven't caused too damage already running it without fluid. If you are lucky that way you still have to address the leak, hopefully it's at the coolant lines or pan, or fill neck, and not something more complicated.
krapug1
Feb 3, 2014 01:12 PM
saint76
Feb 17, 2011 11:13 PM
nscoville 87' 760
Jun 10, 2010 12:27 AM
ltd
Jun 24, 2008 12:23 PM
volvoyoungster
Feb 21, 2007 09:09 PM
