Whiteblocks- Can the cams move freely when the crank is at 0°?
Old Jan 5, 2024 | 01:14 AM
Arkodios's Avatar
Default Whiteblocks- Can the cams move freely when the crank is at 0°?
I’ve been replacing the head gasket on my 1997 Volvo 960. I just put the valve/cam cover on with the anaerobic sealant. The video I watched by Robert DIY, where he talks about whiteblock volvo head removal, he said that you can move the cams 360° when the crank is on mark (0°, not TDC). Since he’s working on a 5 cyl, I wanted to double check this. On some post on another forum someone was talking about their 960 and needed timing help, someone confirmed that you can move the cams 360° when the crank is at 0°.
I was feeling confident about this, I had my earbuds in, but as I was rotating the intake cam to put it at its 0°, I got the bright idea to take my earbuds out so that I could listen and I’m definitely certain I heard an off noise coming from the engine along with some resistance. I figured some resistance was normal as the cams push on the valves but now I’m doubting myself and believe I may have bent some valves on both the exhaust and intake side. Can anyone confirm or deny that the cams can move freely when the crank is at 0°? I have the Chiton handbook and it doesn’t make any mention of it, it doesn’t even seem to explicitly mention that it’s an interference engine. Any help would be appreciated
Old Nov 13, 2025 | 10:59 AM
SaltyDog's Avatar
Why rotate the cams fer?
s40dad
Jun 14, 2013 10:34 AM
Xazar
May 30, 2013 08:36 AM
danborisuk
Aug 1, 2012 07:42 AM
bigdummy
Jun 25, 2009 07:35 PM
gemuth
Feb 28, 2009 08:07 AM
