1994 850 No Speedo & Flashing Arrow
Old Sep 12, 2012 | 08:47 PM
rccVolvo's Avatar
Default 1994 850 No Speedo & Flashing Arrow
Automatic, No Tracs, No Turbo
Car was shifting oddly, flashing arrow came on and speedometer stopped working.
Code 232, 313
Replaced PnP, VSS, Mode Selector Switch.
Car runs great, shifts like it is supposed to, alas still no speedometer and arrow continues flashing unabated, mocking me even !
So swapped out Instrument Cluster with known good one, nope.
Swapped out ABS module with known good one, nope.
Swapped out TCM with known good one one, nope.
Still no speedometer and flashing arrow continues.
Is it possible the ignition switch could cause this. I have tried jiggling it but to no avail. Should I replace it? Does any other component send speed signals or is in the loop ?
Any ideas? The car only has 84k on it, And is in great shape, but I am at wits end.
Old Oct 22, 2012 | 09:20 PM
rccVolvo's Avatar
Ended up being the Instrument Cluster. Checked the Ohms (terminals 2&3) on IC I thought was good - 0hm reading way off. Obtained used VDO IC plugged it in and problem fixed.
Old Jan 20, 2020 | 11:00 AM
JD1965's Avatar
Thanks for sharing/reporting.
va740twagon
Jan 8, 2020 01:51 PM
Radfordalum
Feb 27, 2016 09:09 PM
Rick Almeida
Nov 18, 2015 10:09 AM
pennjam1
Mar 11, 2012 05:54 AM
cacique17
Jul 16, 2011 02:44 PM
