1994 interior lights all out
Old Jul 21, 2010 | 07:00 PM
dan1232's Avatar
Default 1994 interior lights all out
all of the interior lights are out in our 1994 850. i checked the fuse which i believe is number three. the fuse was not broken. they worked the other day. any suggestions? i might be looking at the wrong fuse any one know the right fuse number if its not 3, thanks
Old Jul 22, 2010 | 06:47 PM
Do they work when you try the switches?
Old Jul 23, 2010 | 11:29 AM
boxpin's Avatar
Also try the switch above your rear view mirror, between the drivers and passengers map lights.
Old Jul 23, 2010 | 12:06 PM
vjaneczko's Avatar
Check the door pin switches, too. One may be gummed-up and in the closed position.
Old Jul 24, 2010 | 12:43 PM
boxpin's Avatar
These cars dont have traditional door pins, they are built into the latches. Not an easy thing to check. Not to mention...none of the doors are turning on the lights. The likelyhood that all door pin switches failed at the same time would be something for Guinness.
wgan
Oct 27, 2014 09:05 AM
benschumacher
Aug 13, 2010 02:43 PM
Scott6
Aug 13, 2008 06:12 PM
97GLT
Jul 15, 2008 09:04 PM
kathleen
Apr 3, 2007 08:27 PM
