2 turbo questions:
Old May 5, 2011 | 01:20 PM
ibified's Avatar
Default 2 turbo questions:
I have two questions: im swapping my turbo and exhaust this weekend (finally) and already got the copper crush washers for the oil lines and coolant lines. Now I'm wondering if there is a gasket of any kind between the turbo and exhaust manifold. Also wondering if theres a gasket between the turbo and downpipe. Thanks!
Old May 5, 2011 | 01:24 PM
mike1976's Avatar
Smile
should be mine are green phone and ask your volvo parts supplier should cost about £1.70 or $3.00
Old May 5, 2011 | 02:10 PM
Mad Matt's Avatar
Put my 18T on my 850 a couple weeks ago.
There is no gaskets between the turbo and Manifold or the turbo and the downpipe. My indie tech that helped me with the job put a layer of RTV between the turbo and DP though. Only other gasket you'll need is for the oil return pipe, and I'd get a new O-Ring for the return pipe where it goes into the oil pan.
That is per my dealer who is an enthusiast with an 18T on his car as well.
Old May 5, 2011 | 06:50 PM
A tip on the exhaust install if you are installing it all. Unless you get the rear really high cut off the last 1 to 1.5 foot of the exhaust. That will make it alot easier to get it out.
Old May 6, 2011 | 01:08 AM
ibified's Avatar
Thanks for the tip, Tech. I have a sawzall out there for that very contingency.
Thanks for all the replies all, I will post pics when done.
Phil 850
Jul 25, 2012 10:01 PM
AnEskimo
Sep 25, 2010 08:32 AM
1Gray760T
Nov 13, 2009 08:19 PM
sean
Jun 5, 2005 07:42 AM
ferrarivdub
Dec 22, 2004 08:38 PM
