2nd Transmission: broke under 40,000 miles
Old Sep 12, 2010 | 01:59 PM
850forum's Avatar
Default 2nd Transmission: broke under 20,000 miles
I have a 1995 850 turbo wagon. My mechanic installed a rebuilt transmission obtained from a dealer less than 40,000 miles ago.
EDIT: correction - less than 20,000 miles
This weekend it failed -- I started the car and drove, but it didn't engage correctly & follow engine revs, then it went "clunk" "snap" and didn't feel like it was responding to engine revs.
I pulled over and went thru the shift from P to D and I discovered it would not go in reverse.
In fact, the wheels won't rotate backwards even in neutral. Had to drag it off the tow truck with a chain hooked to another car.
The dealer went out of business; only a 1 year warranty anyway; but this is just not acceptable, a tranny should not fall apart this soon.
Old Sep 12, 2010 | 06:01 PM
Rebuilt transmissions for these 850's usually never work out. The transmissions do not like to be rebuilt.
Old Sep 12, 2010 | 09:41 PM
boxpin's Avatar
Pick one up from a wrecker. The Pick N Pull here has about 5 auto trans. I think they are $75.
Old Sep 12, 2010 | 11:09 PM
850forum's Avatar
Maybe I could stock up & get a discount.
Do these transmissions tend to either last forever or fail early?
10 hours installation at $90/hr for whatever they bolt on...
Old Sep 13, 2010 | 06:06 AM
They are one of the weakest points as far as the engine and driveline.
Old Sep 14, 2010 | 11:22 AM
850forum's Avatar
Correction -- less than 20,000 miles.
How does the Volvo rebuild quality control system work -- should Regional Volvo have a record of the tranmission serial number?
It bothers me that the dealer who supplied it went out of business suddenly; literally a day or two after supplying it.
Wondering if they just sold a unit off a junker instead of a certified rebuilt unit, knowing they were not going to be around to answer for it.
Can I supply Volvo with the serial number and get them to prove it was rebuilt?
Old Sep 14, 2010 | 08:34 PM
If it was a Volvo dealer I would stop by the next closest one and talk to them.
Old Sep 14, 2010 | 10:19 PM
You could also call the 800 North America number and check with them.
MyCorvette
Sep 2, 2014 09:37 AM
VolvoD
Jun 28, 2010 08:28 AM
trailfan
Sep 1, 2009 02:27 PM
yellowtr6
Apr 27, 2005 01:36 AM
