850 and 302 brakes Bracket help
Old Jun 30, 2015 | 08:21 PM
jjon667's Avatar
Default 850 and 302 brakes Bracket help
hey guys how are you. I am going to convert my 850 with 280mm to 302. I have caliper brackets from a 2000 s60 but the brackets may not be correct. I am hoping you can help.
The caliper bracket I have is stamped ATE 332 on the inside. There is also a G stamped with a circle around it.
do you guys have any info or experience with the brackets and upgrade? Does any body low about the stamping ID?
Thanks!!
Jon
Old Jul 1, 2015 | 10:57 AM
my guess is the G stamp is a manufacturer's brand like Girling. A few sites sold a kit (check IPD USA and FCP Euro) which basically used the original calipers and the newer Volvo brackets to move the calipers further out so you can install the larger disks used on the newer model. Try searching for other posts or google for 850 brake upgrades. I found this one:
https://volvoforums.com/forum/volvo-...de-t5-r-69862/
coryfrench
Dec 1, 2014 06:54 PM
TestPoint
Dec 30, 2013 04:35 AM
v1lcins
Apr 6, 2013 06:14 AM
gilber33
May 7, 2011 02:35 PM
bulldog
Dec 7, 2008 08:17 AM
