850 Auto trans seal leak
Old 06-06-2005 | 12:46 PM
etype38's Avatar
Default 850 Auto trans seal leak
I have an 850 with an automatic trans that has just started leaking at the transmission output shaft seal. It at least looks like it is from the seal.
Can it be replaced in the car?
Paul Gavaza
Old 06-06-2005 | 12:59 PM
Default RE: 850 Auto trans seal leak
Do you mean it is leaking from one of the axles?
Old 06-06-2005 | 01:02 PM
etype38's Avatar
Yes, it is leaking from where the black tube going to the passenger side wheel meets the transmission. This is located almost directly above the trans drain plug.
Old 06-06-2005 | 01:31 PM
Yes you can replace that seal without removing the trans.You will just need to pull the axle.
Old 06-06-2005 | 03:52 PM
etype38's Avatar
Thanks very much.
The axle removal looks fairly straight forward. I cleaned the area up and will hopefully confirm the leak source after a few days running. I hope it isn't the engine rear seal with oil being flung out of the exposed flywheel area above the axle, but it looks like ATF.
Old 06-06-2005 | 04:05 PM
Keep me posted on your progress!!!
nortons
02-22-2015 11:14 PM
VolPat
06-15-2012 08:06 PM
ded137t5r
06-10-2012 07:40 PM
Optimized1975
01-31-2009 05:51 PM
eliezer
01-12-2008 05:00 PM
Quick Reply: 850 Auto trans seal leak
