850 R hub exchange problem
Old Sep 28, 2009 | 06:07 PM
boldtu's Avatar
Default 850 R hub exchange problem
I replaced the hubs on my 97' R wagon. Part of the process was unplugging the electrical connection to the housing. Now the TRACS is indicated as being OFF all the time, and my ABS light is on. Do I need a machine to reset this or is there another way?
Thanks,
Chet
Old Sep 28, 2009 | 07:18 PM
Did you leave it unplugged?
You will need a scanner to clear them.
Old Sep 28, 2009 | 09:18 PM
boldtu's Avatar
Yeah, made that mistake at first( lest them unplugged). After I figured it out I plugged it back in, they came on, now they have turned off. The car healed itself!
Thanks,
Chet
Old Sep 28, 2009 | 09:19 PM
Well the codes are still there but working on clearing them selves.
Old Sep 29, 2009 | 01:09 AM
boldtu's Avatar
Is there anything that I need to do? will they still function properly?
Thanks for all of your help,
Chet
Old Sep 29, 2009 | 06:43 PM
Eventually if there is no fault they will clear.
Try locking up the brakes SAFELY on gravel and see if the ABS works.
Usually when codes are stored ABS will not work.
Old Sep 30, 2009 | 11:23 AM
boldtu's Avatar
Great, Thank you again for all of your help
Old Sep 30, 2009 | 06:42 PM
Your welcome anytime.
puxnstx
Dec 13, 2014 11:36 AM
Dan Prado
Nov 2, 2007 05:48 PM
johnsain3
Mar 14, 2006 09:11 PM
homeagri
Feb 18, 2006 10:33 PM
homeagri
Feb 16, 2006 10:12 PM
