850 turbo
Old Nov 14, 2008 | 09:24 AM
Janus3's Avatar
Default 850 turbo
I recently purchased a 95 850 turbo, runs well, does not overheat or overpressure the coolant tank, I noticed a little blue smoke and moisture out the exhaust. Is it possible the turbo could be worn enough to leak water into the exhaust?
Old Nov 14, 2008 | 10:18 AM
JPN's Avatar
JPN
Default RE: 850 turbo
No, your 850 is not burning coolant; it is burning engine oil.
Somewhere in the engine/turbocharger, there is an oil leak. Keep checking the oil level frequently and maintain the level near the top limit of the dipstick and have problem corrected asap. Also, if your 850 has not have the PCV component replacement, I would do that too.
General servicing reference:
https://volvoforums.com/m_48928/tm.htm
JPN
Old Nov 15, 2008 | 09:06 AM
Check the thermostat for the over heating problem.
Old Nov 17, 2008 | 08:54 AM
Psaboic's Avatar
Are you parking it facing downhill? Our 95 Turbo gives a small puff of blue smoke on startup, but only if it is parked on a downhill incline for 4+ hours
Keith Tobberman
Sep 30, 2011 10:36 AM
1Gray760T
Nov 13, 2009 08:19 PM
eddiecortes112683
Feb 22, 2009 08:37 AM
Keith Tobberman
Oct 23, 2007 08:33 AM
pvolvoman
Aug 14, 2006 12:48 PM
