93' 850 A/C problem
Old Feb 27, 2008 | 02:24 PM
por935's Avatar
Default 93' 850 A/C problem
I just tried to charge the a/c in my 93' 850. Turn on the a/c switch, and it took a can of 134A, but the compressor never kicked in. I checked voltage to the pressure switch, and no voltage. I hot wired the lead at the pressure switch to see if it would kick in and get cold. It did come on for about 2 minutes. I have noticed at start up the Rec and A/C lights flash about 18 times. Have not checked the a/c switch on control panel yet. Anyone know what's going on?
Old Feb 27, 2008 | 02:40 PM
Maxbaby's Avatar
Default RE: 93' 850 A/C problem
Did you read your codes?
Old Feb 27, 2008 | 06:44 PM
Read the codes and clear them first.
Old Feb 27, 2008 | 07:20 PM
JPN's Avatar
JPN
And please note that the compressor is noted for failure, and the evaporator is guaranteed for failure.
JPN
Old Feb 27, 2008 | 08:01 PM
Ozark Lee's Avatar
My procedure for dealing with an A/C recharge is to draw the system to a vacuum. I have a 20 ish dollar vacuum pump that actually works off of an air compressor that I picked up at Harbor Freight.
After I pull the vacuum it will usually, depending on the outside temperature,suck in the first can of R-134A and the switch will kick in and let me charge it all the way up.
I hope you didn't jumper the switch and just let the compressor run without feeding it refrigerant. That would be bad as the compressor is not getting oil.
...Lee
Old Feb 29, 2008 | 04:48 AM
Volgrrr's Avatar
ORIGINAL: JPN
JPN
I was driving along minding my own business about 5 days back when allthe dashboard warninglightssuddenly illuminated. When I recovered from theinitial fright - I realised the warning lights were for things like the handbrake was on,coolant level was low,bulbfailure etc. etc. which made no sense at all to me as the coolant level was perfect, the handbrake was definitely off and everyglobe were functioning O.K.
I called out the local breakdown people and they drove it to their garage andestablished the real fault was aseized bearing in the A/C compressor.
Why did all these lights come on if it was onlya seized bearing?
Well,theseized bearing had caused the serpentine belt to slip andslow up to such an extent that, effectively, thealternator wasn't being rotatedquickly enough which in turn caused thealternator fault light to illuminate.
Still not making much sense eh! Well, here is the interesting part.
I then had a thorough look through all the Volvo information I could get my hands on and eventually found, tucked away in a section of VADIS,the explanation. According to VADIS when the alternator light comes on it, in conjunction with an ECU,brings up the coolant level, handbrake, bulb failure etc. etc. lights.
Thought I'd better post my experience and let all you other guysknow too - just in case anyone else may run into thisstupid problem.
s70_t5_1999
Jan 22, 2010 11:53 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
