93 850 GLT Condenser
Old Jan 27, 2008 | 09:41 AM
jlarma's Avatar
Default 93 850 GLT Condenser
i replaced the condenser in my 93 850 GLT, it appears as though the connection for the inlet from the compressor is a right hand thread, can anyone confirm this for me. I am wondering if the hose was replaced with the wrong one at one time as I am the second owner(145K) the AC did not work previous to a deer collision, which took out the radiatior, condenser, headlights, header panel hood...etc. The condenser inlet connection will not thread on, the outlet connection threaded fine, i also noticed the hoses for sale are either 93 or 94-97 which leads me to believe my right hand thread theory is correct, i have not found supporting evidence however. I pulled the fitting off of the old cond,and it looked as though the hose fiting had stripped it completely, HELP please.
Old Jan 27, 2008 | 09:52 AM
Default RE: 93 850 GLT Condenser
Most likely the threads came off the old condenser and are stuck in the line nut.
Old Jan 27, 2008 | 10:02 AM
jlarma's Avatar
How do you recommend i clean them out, this makes much sense, are they right hand threads on the condenser?
Old Jan 27, 2008 | 10:18 AM
Everything shound be normal right hand threads. Either you will have to find a Tap that will fit into the hose. Or find a new line.
klaus
Sep 3, 2009 12:18 PM
reidb1
Jul 6, 2008 11:17 PM
SC Surfer
Apr 22, 2008 11:29 AM
Turkey_Sandwich
Oct 28, 2007 08:07 PM
candodad
Aug 8, 2007 07:19 PM
