94-850 na Idles for a few seconds- croaks
Old Nov 11, 2008 | 09:22 PM
  #21
Default RE: 94-850 na Idles for a few seconds- croaks
HMM still haves me a little baffled I wish I was close to see the car and perform tests on it myself.
Can you gain access to a fuel pressure guage?
Old Nov 12, 2008 | 02:13 AM
  #22
Adrenalin540's Avatar
Ya I think I can get one today...not sure. I'lll give it a go and report back...
Old Nov 13, 2008 | 02:31 AM
  #23
Still no fuel pressure gauge, yesterday I coiuldn't get access to this site so I got to another forum and they seem to think the IACV may still be bad? Maybe? I 'completed' my headliner repair yesterday and have to detail my interior and do some small stuff to the interior, but my project Volvo is coming nicely. I just have to get this 'idling issue' resolved...
Thanks again guys!
I'll update this to remedy or my pursuit of my idling issue...
Old Nov 13, 2008 | 10:04 AM
  #24
JPN's Avatar
JPN
I would re-check the following items:
- Throttle switch
- Throttle position sensor
- Coolant temp sensor
- MAF, even though you have already tested it
- Camshaft Position sensor
- Disconnect the negative battery cable, wait 15 minutes, pull out the ECU, spray contact cleaner onto the pins on the ECU & its receptacle, make the ECU re-learn idle by starting the engine with as little electrical power as possible (do not step on the brakes, as the brake lights will consume some power) and let the engine idle for 10 minutes.
JPN
Old Nov 13, 2008 | 02:00 PM
  #25
Quick question...do you have to have the IACV to start the car?
Old Nov 13, 2008 | 03:53 PM
  #26
Its a good Idea. It will not idle and will cause a bit leak of the holes aren't plugged.
Old Nov 13, 2008 | 05:52 PM
  #27
reason being today i put the covers on the engine iacv was vibrating, so i tapped it with a hammer, and my car hasn't started since...
Old Nov 13, 2008 | 05:57 PM
  #28
It might be totally bad now.
Old Nov 13, 2008 | 06:31 PM
  #29
In the meantime I pulled the fuel pump too...but when I hook power to it...it seems to run just fine...is there some way to tell?
Tech...thanks! You are a very patient person and that is good in dealing with us MORONS...LOL
Seriously... Thank You
So right now I am stuck between the IACV and the fuel pump, I think I'll just get the IACV and try it...if it works YIPPIE, if not then I go for the fuel pump...but when I pulled the plugs they were wet...
Old Nov 13, 2008 | 06:35 PM
  #30
I have seen some of the fuel pumps not work in the car but then when bench tested they work fine.
You can get the motor for the assembly pretty cheap and install it in your housing.
The only real way to tell would be to find a fuel pressure guage and leave it connected and watch it.
Old Nov 13, 2008 | 06:44 PM
  #31
Where do you get the motor? Just in case, I think tomorrow I will get the IACV and hopefully that resolves my issue, if not I'll go for the pump...
Old Nov 13, 2008 | 06:49 PM
  #32
I think FCPgroton.com sells the motors seperate.
Old Nov 13, 2008 | 07:34 PM
  #33
JPN's Avatar
JPN
This one is for 1996 non-turbo and is kind of steep. I could not find the motor alone. Other sensors seemed not too bad, such as throttle position sensor/coolant temp sensor. TPS, an aftermarket version was mere $28 or so.
http://www.fcpgroton.com/product-exe...ategory_id/155
JPN
Old Nov 13, 2008 | 07:45 PM
  #34
Thanks JPN...I'll keep it in mind...
I think I located a good used IACV for starters...lets see where this goes.
Old Nov 14, 2008 | 11:28 AM
  #35
Well today I found a local bone yard that had a 96 850 turbo, so I took the fuel pump...put it in and it started right away reved up to 2k then stalled out, hasn't started since? Any Ideas??? I still haven't replaced the Idle Air Control Valve, but that is next...
Thanks again
This is the edit part...
I was thinking that its starting and running may have had more to do with an ECU 'learning' idle' again rather than the influence of the new pump. I removed the fuel pump last night...went to the bone yard this Morning and put the new one in. After I installed it I reconnected the battery, that is when it fired right back up...maybe nothing at all to do with the fuel pump... Hmmm this may be a clue for someone...but it is beyond me!
Old Nov 14, 2008 | 07:13 PM
  #36
Another update...this time it starts every time, when I got to thinking about what happened, I wondered if my drive being on a slope could have any influence, so I put more gas in it....starts every time, but just for a few seconds then croaks...so I am back to the idle air control...I do believe that is my problem...good ignition and good starts just no idle at all and seems to choke out within a few seconds if I dont' give it gas...then I do have to nurse it to keep it going...
This car will run soon...thanks everyone!
Old Nov 15, 2008 | 07:58 AM
  #37
JPN's Avatar
JPN
Will wait for the update.
JPN
DadsVolvo
Feb 27, 2011 11:40 PM
dman777
Mar 24, 2010 04:53 AM
victory
Feb 11, 2009 07:39 PM
samloz
Oct 15, 2007 07:15 PM
dbehr
Sep 30, 2004 09:46 AM
