96 850 starter problem
Old Apr 16, 2005 | 11:50 PM
kermitthefrog's Avatar
Default 96 850 starter problem
seems to want to turn over...then after anywhere from 10-25 cranks, finally turns over and starts..starter seems to be spinning but not engaging?
had the battery checked...but it was ok..what should i do next???
thanks
jim
Old Apr 17, 2005 | 01:27 AM
Default RE: 96 850 starter problem
If you can find the starter try to have someone tap it as you turn the key to start it.
When this happens the engine is not spinning at all?
Old Apr 17, 2005 | 07:23 PM
stater under the exhaust manifold???
Old Apr 17, 2005 | 08:01 PM
The starter is located under the intake manifold on the front of the engine.
LoudSilence
Jun 29, 2009 08:09 PM
stecz
Jun 24, 2007 05:54 PM
brownnb
Jun 11, 2007 10:59 PM
brownnb
Jun 11, 2007 05:09 AM
echaikin
Sep 27, 2006 10:56 PM
