850 starter problem
Old Jun 24, 2007 | 03:48 PM
stecz's Avatar
Default 850 starter problem
re: '93 850 GLT (non-turbo) 5-speed
I think it's really the solenoid.... but... My son started the car and all electricals were dead (although the car was running). The A/C didn't work, windows wouldn't roll down, no radio, etc. He drove the car home (less than 3 miles).
When I went to go lok at it, it wouldn't start. All the electricals worked, but when I turn on the starter, I can hear the starter motor spinning, but it doesn't enage with the flywheel. I then push started it, it worked fine and all electrical systems worked...
So, it sounds like the solenoid stuck on and now it's disengaged, but won't re-engage. After push starting it, it acted exacly the same when I tried to start it with the starter, so I don't think there is a bad place on the flywheel.
Any other ideas?
I'm just going to get a new starter/solenoid and swap it out. Any hints there, is there anything extra tough about doing that?
John S.
Old Jun 24, 2007 | 05:44 PM
Default RE: 850 starter problem
I would get a starter and replace. I never trust just the soleniod.
You might also have a bad electrical part of the ignition switch going bad.
Old Jun 24, 2007 | 05:52 PM
stecz's Avatar
Yeah, I was going to replace both, not just the solenoid... I assume they are integrated anyway...
Old Jun 24, 2007 | 05:54 PM
Pretty much yes but I think you can buy just the soleniod but I never trust just that.
LoudSilence
Jun 29, 2009 08:09 PM
brownnb
Jun 11, 2007 10:59 PM
brownnb
Jun 11, 2007 05:09 AM
echaikin
Sep 27, 2006 10:56 PM
kermitthefrog
Apr 17, 2005 08:01 PM
