96 850 won't start rough diagnosis complete - need a guru
Old May 23, 2010 | 04:29 PM
neveret's Avatar
Default 96 850 won't start rough diagnosis complete - need a guru
I started up the volvo wagon yesterday to pull it up farther in my driveway and I ran just fine. Today my wife went to start it and it just missed and then died. It cranks over fine, and I checked for fuel and spark and I have both (fuel pump running, visually checked spark). Is there a way to check the crank and cam sensors to see if that is the problem or is there something else I have missed in my day long search.
thanks in advance
Old May 23, 2010 | 11:36 PM
gdog's Avatar
You didn't hear a mechanical crunch when it stopped running did you?
I would ck fuel pressure; if that's good then ck compression.
Old May 24, 2010 | 11:32 AM
neveret's Avatar
no mechanical crunch
checked the fuel pressure - 40+psi
checked compression - 100, 60ish,120,40ish,100
Obviously compression is too low on 2 and 4 but I wouldn't think that would keep it from running. It doesn't really use that much oil, and it's been running fine. I would think it would start and run on three cylinders, but maybe it's time to send this one off to the junk yard.
Old May 24, 2010 | 10:20 PM
gdog's Avatar
Compression is low across the board; should be at least 160 or more.
I would pop off the timing belt cover (one bolt) and ck the cam timing just to make sure one/both of the cams didn't jump a tooth. Assuming not, it's OH or junkyard time.
Old May 25, 2010 | 10:27 AM
1996850turbo's Avatar
Check the cam timing,
If I remember correctly you will not have SPARK if the cam and crank sensors are not functioning?
Also,
How did you check spark?
I have seen a bad rotor cause this problem, spark at the coil but with a bad rotor NO SPARK at the plugs.
Moetheshmoe
Jul 31, 2015 11:34 PM
'82CO244
Jun 12, 2015 10:18 PM
mujastarrr
2001-2013 model year V70
Dec 14, 2012 11:00 PM
ZaphodBblbrux
Nov 16, 2012 07:59 PM
PAVolvo850
Jul 11, 2012 05:23 AM
