96 854t timing issue..
Old Feb 3, 2009 | 02:12 PM
T3AMVOLVO720's Avatar
Exclamation 96 854t timing issue..
ok so i just got my block back from the machine shop
put the new H-Beams and new pistons in put the motor back together
drop it inthe bay
make sure everythings ok before starting numerous times
but when i cranked it
aleready i could tell it was misfiring
check the wires and distributer all in the correct order
so i redo the timing once more
Cylinder #1 TDC
made sure everything was perfect
put the tensioner on
Start it
still misfiring
im stuck on this one any help?
thanks for all help.
Old Feb 3, 2009 | 02:46 PM
bestharry's Avatar
Have do done the compression check? - valve might be stuck or bad?
All injector connectors connected?
MAF sensor connector?
CEL light? - any codes?
Old Feb 3, 2009 | 02:54 PM
did a compression test they are all in range
all injectors are good and plugged in
MAF sensor is connected
all valves are good anything else you can think of?
is there a special way to do reset the timing?
cams wise?
Old Feb 3, 2009 | 03:50 PM
TIPSP's Avatar
Got Boost?
I know that QBM has an adjustment cam tool (Click Here)
It is ~$60, but it has been out of stock for a long time now.
Old Feb 3, 2009 | 04:48 PM
thanks
i just want to know if im doing the timing right..
for the cams no specific spot? as long as its pointed toward the two 90degree cutouts
for me i did both pointed right in the corner on both sides
crank pulley directly meeting the groove from the oil pump right?
Old Feb 3, 2009 | 08:31 PM
As long as all of the timing marks are lined up it should all be right.
Are all the ignition parts new? Maybe cap cracked which cylinder is misfiring?
Old Feb 3, 2009 | 09:10 PM
Ozark Lee's Avatar
How are you determining your spark plug wire positions on the distributor? Haynes is dead wrong as is the '95 OEM Volvo Manual.
This is correct:
http://volvospeed.com/Repair/sparkplugs.php
...Lee
Old Feb 4, 2009 | 02:15 PM
yes all new
MSD Blaster SS coil pack
MSD Custom Wires
MSD 6AL Box
Brand new Distributer Cap
Cylinder #2 is misfiring
tried other wires still misfiring
Almost as if it isnt getting no spark at all
its the cleanest one
but i pull it out
put a plug in its and its got sparkk
thanks lee but thats the order im using
like i have everything in order and perfect but its still
not firing right..
Old Feb 4, 2009 | 09:15 PM
Just because the part is new doesn't always mean its good.
If you stick a plug in the wire #2 after pulling it out of the head and you have no spark either the wire is bad or the cap is bad.
Old Feb 4, 2009 | 10:23 PM
They are all good been over checking everything since the day of the misfire
took number 2(no detonation) msd plugged it and check yes i got alot of spark
tried a volvo wire with the boot yes still spark but not as much because lack of size of wire
but when i put it in the head it comes out the cleanest
looking brand new
theyre all gapped correctly too.
Old Feb 5, 2009 | 08:39 AM
bestharry's Avatar
Swap the injector on #2 with any other cylinder and see if the problem gets passed on.
Old Feb 5, 2009 | 08:22 PM
Compression good in that cylinder?
Old Feb 6, 2009 | 12:23 PM
compression is good in all cylinders
already tried the injector switch
but i got 2 extra sets of em
ill try the second set and then the blue ones
how much psi is suppost to come out of the fuel rail?
Old Feb 6, 2009 | 01:57 PM
TIPSP's Avatar
Got Boost?
From VADIS:
210-380 kPa (30.5 - 55 PSI) (2.1 - 3.8 bar) during driving
300 kPa (43.5 PSI) (3 bar) IGN2
Old Feb 7, 2009 | 09:38 AM
Originally Posted by TIPSP
From VADIS:
+1 That is right
Old Feb 9, 2009 | 12:52 AM
I will see i get my new head tomorrow and bringing it to the machine shop and getting it decked then putting her back together
cant wait to hear her purrr
plus shes still yet to be broken-in
wish me luck it been a long 6 months a
and a good couple motors for the right combination
james_caza
Apr 1, 2010 05:11 PM
T3AMVOLVO720
Feb 3, 2009 02:30 PM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
