97Volvo 850 GLT Gearshift stuck in park
Old Mar 26, 2014 | 04:26 PM
sosi's Avatar
Default 97Volvo 850 GLT Gearshift stuck in park
I have a 97 Volvo 850, the gear shift seemed to have developed a more permanent condition of being stuck in park position. I release the gear shift from park by the release button on the right. This situation crept up gradually over the last year. In the past year I noticed the gear shift sticks for few seconds then releases itself. However lately it does not release itself unless the release button/switch is depressed.
Does any one out there have a clue on how to fix this.
Much appreciated.
Sosi
Old Mar 26, 2014 | 07:10 PM
Hi and welcome to the site.
You likely have an ignition switch problem. Turn the key back just a tiny bit to see if it helps.
Old Mar 28, 2014 | 04:21 PM
sosi's Avatar
Is there a test that could be performed that would point to the cause or reason for "gear stuck in park" problem. I have no problem replacing the ignition switch but what if it is not the problem.
Could it be the PNP neutral switch stuck or need replacement??
I appreciate any comments.
Sosi
Old Mar 28, 2014 | 04:39 PM
sosi's Avatar
Thanks for your help,
I did turn the key slightly several times I also did the gearshift back and forth aver 10 times but the gearshift is still stuck in park and would not release unless I depress the switch on the right of the gear shifter.
Sosi
Obelix
Jun 20, 2022 08:40 AM
Volvo-Finn
Mar 21, 2011 11:47 AM
RGT
Sep 17, 2009 05:16 AM
snuggletime
Apr 25, 2008 08:46 PM
trajan
Jun 27, 2006 01:51 AM
