abs tracs
Old May 6, 2012 | 07:29 PM
cheesenacho's Avatar
Default abs tracs
the abs and tracs light come on intermittently after i used the ebrake a few days ago. i cleaned the front ones the other day when i replaced the front struts and plan on cleaning the rear ones tomorrow. also when i brake the rear vibrates, sometimes bad sometimes not so bad. today i noticed only for the second time when the abs/tracs light came on i heard a buzzing under the hood and the brake pedal vibrated. ideas are welcome as i continue to google the issue, what should i be looking for when im cleaning the rear ones tomorrow, something ebrake related? i know the module may be bad but im going to exhaust all other options before i swap out the unit from the sedan. which brings me to another question will the module from the 95 work in the 97, are they one in the same?
Old May 7, 2012 | 09:40 AM
this is like a diary...
this morning i removed the rear wheels in an attempt to clean the rear abs sensor but it would not budge after removing the 10 mm bolt. i have read people trying to force it out and ended up breaking it so the only other access to it is from the other side so i cleaned it and the tooths and the ebrake assembly which was loose and missing one shoe. ill replace the ebrake and rear shoes. other than that it all looks fine. onto the other side. i beginning to think the module needs to be sent out.
Old May 7, 2012 | 04:14 PM
brianb's Avatar
Mine is similiar but, it's from the front and it's very faint. I just replaced the ABS module with a rebuild from FCP but, it still does it. Completely at a loss on mine.
Old May 7, 2012 | 05:18 PM
i resat the abs module and electrical connectors, drove around a long while...so far so good. i recall looking at it a few weeks ago, maybe i didnt get it sat all the way or moved the module enough to temporarily get the solder joints to connect only time will tell. is it possible the shimmy while braking is coming from the rear shocks being bad and it needing an alignment?
Old May 8, 2012 | 01:49 AM
Oreilly sells the parking brake shoes for 25.99 P/N 820
Old May 8, 2012 | 06:12 PM
Abs/trace light back on after severe rear wheel vibration. Would bad rear shocks cause this vibration. It's real bad going down a hill and applying the brakes, should I concentrate on shocks or rear brake shims.
Old May 8, 2012 | 09:50 PM
If you're only getting the vibration while braking it would pretty much eliminate the shocks as being the cause. Weak shocks could make the problem feel worse but they wouldn't be the cause.
Normally a vibration while braking is caused by out of round drums or warped rotors. Sometimes the warped rotors are caused by the calipers or the mounting hardware seizing in place and not allowing both pads to work equally so one side does most or all the work and overheats causing the warping. That's why just doing a pad slap where just the pads are replaced is such a bad idea. Everything should be taken apart, cleaned up, rotors or drums machined or replaced, old grease/lube removed and fresh hi temp brake lube applied to all contact points. It's more work but you get better braking feel and pad/rotor life when it's done right.
Old May 9, 2012 | 07:07 AM
Looking for a tutorial for a complete rear brake job sounds like a good idea. need suggestions for parts. i usually use fcp and go with oem replacements, what have you used and are happy with the results? im going to replace the ebrake stuff because its trashed, rotors, pads, shims.
Old May 9, 2012 | 09:20 PM
light8008's Avatar
I think you should check the abs and tracs with scanner.
_____________________________________________
tomorrow is the first day of the rest of your life!
Ediabas OBDII interface
paulh
Jan 30, 2008 08:22 PM
Buck
Aug 11, 2006 12:56 AM
rmmagow
Mar 29, 2006 10:28 PM
rpm48
Mar 17, 2006 08:50 PM
vwown3d
Aug 20, 2005 03:01 PM
