AC light flashes when I start the car
Old Mar 17, 2009 | 11:53 AM
Archie's Avatar
Default AC light flashes when I start the car
My 95 volvo 850 turbo started this problem a day or two ago.Any idea what this could be?
Old Mar 17, 2009 | 01:13 PM
MC92's Avatar
Had the same problem at least 3 times in different occasions. I believe it said in the manual somewhere that it might need servicing or checking. I just left it alone and it went away on its own. Never seem to have a problem. He he. Someone on this forum might know what's wrong, but it could be anything involving the a/c. I believe that you can check it from the ( don't remember what's it called) in front of the ecu box in the engine bay.
MC92
Old Mar 17, 2009 | 01:35 PM
MC92's Avatar
I think this is the right one, but I'll give it a shot. Ok, the (dianostic unit) located near the windshield reservoir. Take off the covers on both modules. Take the pin and put it in socket one B. Have ignition on and press button on module A. The led would flash. Write down how many flashes in between flashes till it stops and press again to see other codes. If it repeats the same flashes, then there isn't any other codes. If it reads 1-1-1, then there is no fault code stored which I doubt it would. Hope this helps.
gesellman
Dec 6, 2012 11:05 PM
blankooie
Aug 23, 2008 04:44 PM
dnault
Nov 10, 2007 12:27 AM
Digiboy
Oct 28, 2006 07:25 PM
