after burner code po410and svc reset help
Old Apr 12, 2009 | 08:59 PM
allan's Avatar
Default after burner code po410and svc reset help
whats the trick to reset the oil svc light and any hints as to start to repair afterburner system?
Old Apr 12, 2009 | 09:12 PM
Ozark Lee's Avatar
And your car is what year? The procedures are different depending on the year of the car. Please also explain what you mean by the afterburner system. Are you talking about the catalytic converter?
...Lee
Old Apr 12, 2009 | 09:58 PM
allan's Avatar
97 850 wagon...code refers to a Malfunction in emissions After burner system which runs during the first few minutes at start up...and need to know the trick to resetting the oil change svc light
Old Apr 12, 2009 | 10:00 PM
On the 97 car you need a special tool.
What was the code that referred to the afterburner?
Old Apr 12, 2009 | 10:13 PM
allan's Avatar
code is po410... and can you discribe the SPECIAL tool..is it only available at the dealer$$$$$ which is what im trying to avoid
Old Apr 12, 2009 | 10:30 PM
It is a service light reset tool that is pretty expensive to buy.
That code is for the Air pump system. The pumps commonly fill with water and go bad.
IPD used to sell the tool but they do not now.
Old Apr 12, 2009 | 10:36 PM
allan's Avatar
thanks tech the pump info will give me a good start...my code reader will not reset the light and do not want to go to dealer for the svc light$$$$ reset.
Old Apr 12, 2009 | 10:42 PM
See if you have a volvo specialist near you. Maybe next time have the oil change done there to get it reset. Some shops do oil changes for pretty cheap.
Our shop I think is like $40.00 to be somewhat close to the oil change places.
Aikman0008
Jul 19, 2011 10:42 AM
diehardgator1
Jul 12, 2010 07:41 AM
etype38
Oct 3, 2009 08:39 AM
blackhawkMO
Dec 8, 2007 07:55 PM
diehardgator1
Aug 14, 2007 02:08 PM
