Alignment help...
Old Nov 30, 2008 | 01:30 AM
Arsenal6's Avatar
Default Alignment help...
Help...tires got a lump...recently i jumped over a really high curb and my steering feels weird could it be I damaged the alignment? I hate to ask but to what extent?
Old Nov 30, 2008 | 07:24 AM
Default RE: Alignment help...
I would have the front end inspected sounds like you might have bent something.
Only a physical inspection will tell what it bent. Yes you could have also knocked the alignment out pretty bad to.
Old Nov 30, 2008 | 09:59 AM
Psaboic's Avatar
Or atthe very least broke some steel belts in the tire
Old Nov 30, 2008 | 10:32 AM
TIPSP's Avatar
Got Boost?
Could have also bent the rim.
Old Nov 30, 2008 | 11:28 AM
Arsenal6's Avatar
would i be able to c right away if the rim was bent? I am worried about that the tire is gone for sure...
Old Nov 30, 2008 | 11:29 AM
If the rim is bent you should be able to see it.
Old Nov 30, 2008 | 11:36 AM
TIPSP's Avatar
Got Boost?
ORIGINAL: Arsenal6
Take it off the car though. You will need to check the whole rim and not just the outside edge, unless you can see the whole rim on the car.
Old Nov 30, 2008 | 11:41 AM
Arsenal6's Avatar
yeah thats what I was thinking too...but would I feel anything if there was?
Old Nov 30, 2008 | 11:45 AM
TIPSP's Avatar
Got Boost?
Most likely yes. It is best thought to listen to Tech and get the alignment checked.
Old Nov 30, 2008 | 11:49 AM
Arsenal6's Avatar
Definitely have to get alignment check probably when I get the winters...
So far I haven't heard anything different when I drive, would it be really apparent if the rim was bent?
Old Nov 30, 2008 | 11:51 AM
Quick Brick's Avatar
WEIRD HOW?
What is the car doing nowthat it didnt do before?
How tall was the curb?
How fast were you going?
Did you hit the curb straight on or at an angle and which side of the car did it happen to?
Chances are that you may have a bit of both problems, damage tire and an alignment issue. If you hit the curb at any sort of angle faster than a couple of mph then an alignment is needed.
It should be easy to see. Check both sides of the wheel as it may be bent/damaged on the inside lip - side of wheel always under the car.
Hey, at least your is running. Mines in the shop getting a transmission replaced.[]
Later.
Old Nov 30, 2008 | 11:52 AM
TIPSP's Avatar
Got Boost?
Depends on how bad the bent rim is, but you wouldfeel it.
Quick: Hope you can actually get to use that car of yours
Old Nov 30, 2008 | 11:59 AM
Arsenal6's Avatar
The steering feels a little limp compared to before...could be the power steering fluid that was added recently not sure...
The curb was maybe a quarter taller than that of a regular curb
What other types of damage could I expect? Wheel bearing?
Thanks for the tip brick I will check!
Yeah I had my exhaust manifold changed just the other day and this happens I am very disappointed in myself
Old Nov 30, 2008 | 01:14 PM
Dont be disappointed, just more careful.
And Oh God! Please! Lets not talk about exhausts as I think I have a leak up front as I can hear the sound more from the front that the rear. And I still have a heater core to replace[:@].
Does the car track straight when you are moving and let go of the steering wheel? Does it pull to one side or the other? Do you have any vibration in the steering wheelwhen moving or braking?
Later.
If you think that it may be the tire, raise the car and feel, flat palmed, around the wheel to feel for any bumps in the tread. If youve damaged a belt in the tire it will cause different feelings innthe steering wheel when you drive the car.
As much info as you can give will help to diagnos your problem.
Later.
Old Dec 1, 2008 | 08:23 AM
Psaboic's Avatar
At the very least I wouuld swap the front tires to the rear to see if it changes the issue. For safety reasons this is a good idea (in my opinion) My sister-in-lawhad a front tire blow out within 250 miles after a decnet hit on the curb. If one of the tires does let go, at least it will be on the rear
KCB1988
Dec 19, 2013 03:42 AM
QuickBrickRacing
Oct 3, 2012 11:57 PM
volvoedmonton
Sep 8, 2011 11:08 PM
merlinx
Jul 28, 2010 11:18 PM
Osmenthe
Jul 9, 2005 01:36 PM
