All Dash Lights on; TRANS in Winter Mode!
Old Jan 27, 2009 | 02:00 PM
850GLE's Avatar
Default All Dash Lights on; TRANS in Winter Mode!
Hi,
My 1996 Volvo 850 (with 420,000km) just started lighting upALL of the dash 'service' lights (parking brake on, abs, service light, etc...) intermittently while driving. They would flicker on (stay on for a few seconds) then shut off and turn on again... this happened the entire time I was driving. Sometimes, it would be a minute or two before they would ALL turn on again, then shut off after a few seconds.
Then, as I was driving (with these lights flickering off and on), my transmission decides to shift into WINTER MODE and then stays locked in it until I stop the car.
I shut off the car, went to start the car,but the starter wouldn't even click.I would just be able to turn it all the wayto the point when it SHOULD HAVE BEEN on, but it wasn't. After a few tries of this (and with my driver door open), myVOLVOKEYLESS ENTRY ALARMcomes on!!!!
I tried taking the key out, and using the remote to unlock and lock the car, as well as the lock/unlock button on the dash (to the left of the steering wheel).
Thankfully after around 40 seconds, the alarm stopped not sure why really then after I locked it with my keyless remote (and walked away), the hazard lights stayed lit for another minute or so after. Then they shut off.
My mechanic said that some BMW's exhibit that type of problem when the alternator is bad...
Hmmm.......... What is going on??
Old Jan 27, 2009 | 02:54 PM
arzy's Avatar
Default RE: All Dash Lights on; TRANS in Winter Mode!
I had a similar problem, turned out to be the alternator
Old Jan 27, 2009 | 03:12 PM
850GLE's Avatar
Thanks for your response.
Well,my mechanic tested the battery AND the alternator and they both tested fine!!!
He said there may be a defective/faulty diode, but it tested fine for him!
Any other thoughts???
Old Jan 27, 2009 | 09:51 PM
Ozark Lee's Avatar
Try to jiggle the key and see if things change. The electrical portion of the ignition switch is a high failure rate item on these cars and they tend to actpossessed like the symptoms you describe when they go bad.
The good news is that it is a fairly cheap part and it is a snap to fix.
...Lee
prepg
Jan 21, 2020 06:44 AM
fadam
Oct 16, 2017 06:27 AM
cool_kyle_3000
Aug 26, 2008 07:05 PM
tupapison
May 12, 2006 11:26 PM
fatduck
May 9, 2006 12:06 AM
