axles replaced -- shakes at high speeds
Old Aug 23, 2009 | 02:27 PM
March_Hare's Avatar
Default axles replaced -- shakes at high speeds
Just had my 96 850 Volvo serviced at 90,000 miles. The mechanics replaced the axles, and now the car's steering column will sometimes shake violently for a brief period of time when traveling at 45-65 MPH.
What might be the cause of this? Is it safe for me to drive on the freeway back to my mechanic?
Old Aug 23, 2009 | 07:55 PM
I would drive it easy back to them and have them fix it.
Old Aug 23, 2009 | 08:11 PM
March_Hare's Avatar
Do you have any idea what specifically might be causing this problem?
Old Aug 23, 2009 | 08:16 PM
Actually rethinking here double check the lugs first to make sure they are tight.
If that is all good then maybe the axle might be bad.
Old Aug 23, 2009 | 09:31 PM
Carrots's Avatar
yeah, DON'T go on the freeway until this gets fixed...
Old Aug 24, 2009 | 11:25 AM
bestharry's Avatar
Could be something realted to wheel balanceing as well but if started immediately after the axle replacement, then its something wrong on that end. Let them fix it.
Old Aug 25, 2009 | 03:25 PM
crisb's Avatar
If they fiddled with the struts-to-knuckles to get the axles in, you would need alignment after work was done.
Kenwood
Feb 12, 2009 10:24 AM
pconfar
Dec 10, 2007 06:11 AM
halo2maniak
Nov 20, 2007 11:01 AM
blackstarpower
May 7, 2007 08:02 AM
oragame
Jul 21, 2005 11:42 PM
