Bad Water pump or thermostat
Old Mar 29, 2009 | 09:29 PM
dlaxdal's Avatar
Default Bad Water pump or thermostat
I have a coolant leak I can't find and when I run the car the the coolant does not move when it gets to temp. I think the pressure builds up and it leaks back at the resevoir. I took off the timing belt cover and there was no leak around the water pump. The leak hole was clean.
Any advice?
Old Mar 29, 2009 | 09:57 PM
I would start with a thermostat.
Old Mar 29, 2009 | 11:32 PM
dlaxdal's Avatar
Default What oem
What oem do you recommend
Old Mar 30, 2009 | 07:40 PM
Not to sure about temp it also depends where you live.
Maybe someone in your area will chime in with a good temp one for you.
Old Mar 31, 2009 | 08:56 AM
dlaxdal's Avatar
Default Thermostat
Pulled the thermostat last night and it was broken on the top. Replaced it and should be okay. Thanks. Ordered a haynes manual to take a crack at serpentine belt
Old Apr 8, 2009 | 09:29 AM
dlaxdal's Avatar
Default expansion tank
Finally found a leak on the tank. Replaced it with a new one from FCP. Looks like it is not leaking now. Plastic was real brittle from heat. Help is great on the forum.
Old Apr 8, 2009 | 07:23 PM
Glad it is all good now.
Old Apr 9, 2009 | 08:25 AM
Psaboic's Avatar
Just keep an eye on the coolant level for a few days to make sure all is well.
Dtheswan
May 29, 2015 10:40 AM
PieceKeeper
Nov 18, 2011 09:17 AM
scrap88
Apr 7, 2010 09:23 PM
katiejoyful
Dec 12, 2007 04:49 PM
nvs40
Dec 30, 2006 12:14 AM
