Blower Motor resistor bypass?
Old Dec 4, 2009 | 08:29 PM
Chebucto's Avatar
Default Blower Motor resistor bypass?
Either my blower or resistor is gone. My question is can I rip apart my passenger dash to get to the blower and resistor and pull the resistor, then bypass it with a wire to test the blower before having to pull the blower out?
or do I have to pull the blower out and test it on the bench?
Id like to see if the blower would work as we have a storm coming and I have to work, but I cant buy the resistor till next week.
Thanks in advance.
Old Dec 5, 2009 | 02:42 AM
boxpin's Avatar
Just pull the underbelly on the passenger side off. Then remove the knee bolster and you have access to both. You can test from there. I was able to remove my resistor with only these items out. I have not pulled the fan but my guess is the glove box would need to come out to do that.
Old Dec 5, 2009 | 08:27 AM
Chebucto's Avatar
Thanks, but can I do the wire trick without damaging anything? or for that matter, can I run it with the wire crossed over for a day or two till I get the new resistor?
Old Dec 5, 2009 | 11:54 AM
boxpin's Avatar
I dont see why not. The resistor regulates ground, a straight connection would be full blast.
Old Dec 6, 2009 | 09:57 AM
Chebucto's Avatar
Found the problem, it was power connection to the blower. It has a bad connection and if you apply pressure to the connection, you get power. Just goin to replace the blower.
Thanks for the help.
Old Dec 6, 2009 | 07:46 PM
boxpin's Avatar
Expensive but if you cant fix it thats the way to go.
Nichals
May 20, 2015 07:27 PM
jmallie
Sep 17, 2009 09:47 AM
Benihana
Jan 31, 2009 01:08 AM
Evo 850
Dec 6, 2007 01:51 AM
Evo 850
Nov 24, 2007 05:25 PM
