Brake Indicator Light Stays On
So I was in a hurry and had Pep Boys put on the new front brake rotors, pads and hoses -- I had already done the rears. When I picked up the car, the brake indicator light on the instrument cluster was on. They couldn't figure it out, and I was in too much of a hurry to wait until they did.
The brake fluid is full, the brakes feel firm, I checked to make sure that nothing was leaking. What else could the light be telling me to check?
Thanks
JM
Thanks
JM
RE: Brake Indicator Light Stays On
Maybe it would be easier to just ask what sensors drive this light? Is it just the fluid level sensor? Is there a brake fluid pressure sensor that in the system that is attached to the light? Any wear sensors on the wheels? If I could find out what drives the light, it would allow me to find the problem thru the process of eliminatination.
JM
JM
I believe it has: Fluid level,Fluid pressure and the E-brake.
If you want try looking at this wiring diagram and see if you can find out for sure.
http://www.volvotechinfo.com/WD123/3...%203911202.htm
