brembo vs oem
Old Aug 26, 2010 | 07:14 PM
white83glt's Avatar
Default brembo vs oem
my back rotors need to be replaced and i was about to order the oem's on FCP's website when i noticed that the brembos were about 13$ cheaper than the oems.
i dont do any aggressive braking, but when i owned an integra, i replaced the stock rotors with those and loved the way they felt.
i read that our cars are susceptible to squealing with aftermarket rotors/pads but i was wondering just how bad it really is?
id prefer to go with the brembos, only because i know they were super reliable in my integra.
Old Aug 26, 2010 | 09:02 PM
RobTheModd's Avatar
it doesnt matter tbh, I have aftermarket auto-zone duralast rotors and they work perfectly fine. .
its your pads that make the noise.
just get some break grease, apply to the back of your pads before you install, and you will be good to go, make sure you also apply to the area where the pin goes thru the pad.
aftermarket pads may need special volvo shims due to over heating when not using *volvo* break pads.
rotors are rotors.
Old Aug 26, 2010 | 09:16 PM
white83glt's Avatar
cool, ill go with the brembos then. pads, ill go OEM as theyre pretty cheap as it is.
Old Aug 26, 2010 | 09:23 PM
SVTfocusO3's Avatar
Originally Posted by RobTheModd
rotors are rotors.
I don't think so, Volvo rotors are soft and cannot be cut.
Old Aug 26, 2010 | 11:06 PM
ibified's Avatar
it's not the hardness or softness of rotors that determine if they can be turned or not - it's the thickness they come at. Not sure what discard spec is on our rotors, but MOST new cars today come with rotora that are at discard spec. the reason they do this is because 1) it supports the repair industry 2) it makes the rotating assembly marginally lighter, and 3) it saves them a little bit of money per car on steel.
Old Aug 26, 2010 | 11:31 PM
vjaneczko's Avatar
There's a thread over at MVS about most of the Brembo rotors nowadays are being made in China and are poor quality. I'd call FCP and ask them to pull a pair to find the "Made In" sticker before you buy them.
Old Aug 27, 2010 | 12:13 AM
ibified's Avatar
This is what's going on my car once I get around to doing the brakes:
http://www.tirerack.com/brakes/brake...94&autoModClar=
Old Aug 27, 2010 | 05:00 AM
regime's Avatar
Check out FCP. They do a whole setup with ATE 302mm. Looks like a pretty good kit.
Old Aug 27, 2010 | 08:35 AM
vjaneczko's Avatar
Project I'm wrapping up, featuring Zimmerman rotors:
Old Aug 27, 2010 | 09:00 AM
RobTheModd's Avatar
http://farm5.static.flickr.com/4031/...01cc129a34.jpg
unless you are racing daily, you dont need anything else.
Old Aug 27, 2010 | 08:21 PM
regime's Avatar
I want to upgrade mine, but i don't race every day. I feel the stock on a turbo 850 is WAY to small. I have experienced fade and feel the stop times are generally too long for a car of this weight.
I'm more interested in upgrading size over gimmicks like drilled holes and slots. (that's going to start an argument i know it...)
I know to look for better pads and change out the fluid too guys.
i'm just saying stock seems weak to me.
Let the pooh it the fan...
white83glt
Jan 18, 2011 08:15 PM
PieceKeeper
Sep 14, 2009 09:07 PM
ds1455
Jul 2, 2009 09:13 AM
ds1455
Jun 29, 2009 09:27 AM
Cornfed
Apr 14, 2006 11:36 PM
