Buying a 94 850
Old Aug 2, 2006 | 03:45 AM
Red XC's Avatar
Default Buying a 94 850
Okay. After trying to fix this 94' 850 GLT, the customer doesnt want her car anymore due to safety concerns because the car will stall while driving and at idle. So she is going to sell me at a reasonable price. Does the 94 have any pros and cons? Ill wil need a driver's door stay, possible Evaperator Replacement because it keeps leaking A/C, one rear speaker, antenna, trunk support shocks. I'm wondering if I can install later 850 models with the cd and cass unit? Will the arm rest with the cup holder fit? Just when I fix most of this, I can either keep the car or sell it but mostly keep since this will be our 4th Volvo to our family of volvos which includes 02' XC70, 91' 245, 83' 245.
Also wondering if anybody knows the features.
Old Aug 2, 2006 | 10:08 PM
Default RE: Buying a 94 850
HMMM 1994 so so.
I would fix then sell.
Old Aug 3, 2006 | 03:04 AM
code33's Avatar
Any codes?
Sounds like a fuel delivery problem. Perhaps it is fuel pump relay that is in the fuse box under the hood near the windshield of the driver. I had a similar stalling problem before changing it.
Also, remove the IAC (Idle Air Control) valve and clean it w/ carb cleaner.
Old Oct 1, 2006 | 10:22 PM
MikeySq's Avatar
ORIGINAL: tech
HMMM 1994 so so.
what issues would make the '94 so so
is there anything I should look out for that is known to be a problem?
Old Oct 3, 2006 | 08:29 PM
1993 was the first year for the 850. The 1994 was a little better but still had some problems.
One was the Transmission. The others were minor but annoying.
Old Oct 4, 2006 | 01:04 AM
MikeySq's Avatar
Thinking that it's not a factory item I have high te,p silicone or gasket maker between my tranny and engine so I assume it has been out before. What is bad aboyt the tranny is it a complete lemon? Anything I can do to it or are there tell signs or preemptive steps to help it out?
Where mine has been out is there a date code or a model code which would tell me if I in fact have a 1994 transmission in the car?
I have already flushed about 10 litres of fluid through the tranny and have a good colour of fluid on the dip stick now. There was no signs of metal on the magnetic drain plug at all. It shifts fine on the road and on the ramp, although I have yet to put many miles on it since I've had it it seemed OK when I was driving it.
Thanks
-Mike
Old Oct 4, 2006 | 01:14 AM
No real badge to tell date.
Is the sealer in the transmission or between the engine and trans?
Old Oct 4, 2006 | 01:28 AM
MikeySq's Avatar
actually come to think of it now i'm not sure if it was between the ranny and the engine or if it were an access panel for solenoids or something... can't really remember. it was just one of those things i noticed when it was up on a ramp. I just thought it was not original and that the tranny had been serviced some how before.
Old Oct 4, 2006 | 01:33 AM
MikeySq's Avatar
Oh it's all commin back to me now... looks like a service panel at the end of the transaxle??
is that red stuff original?
see pics may be good for something!
Old Oct 4, 2006 | 08:33 PM
That is silicon sealer that they use from the Factory.
Old Oct 4, 2006 | 08:55 PM
MikeySq's Avatar
woah that seems pretty ghetto for a factory thing, i'd swear that they would have a gasket for those parts from the factory,
silicone sealer?, I thought only driveway monkeys like myself and "mechanics in a a pinch" used that stuff haha
guess not
Old Oct 4, 2006 | 09:36 PM
Pretty much the same applies for your engine.
There is only one Gasket and that is the Headgasket.
spdekold
Aug 5, 2010 03:24 PM
Italiano86
Jan 30, 2007 11:13 PM
rocknroll_1950
Nov 8, 2005 11:09 AM
kup125
Oct 26, 2005 08:38 PM
Benji9k
Nov 25, 2004 10:07 AM
