a/c blower
Old Jun 19, 2007 | 12:50 PM
dumpling's Avatar
Default a/c blower
I did a search and didn't find this, the blower starts out slow even on high speed. After driving for a while it will ramp up, never touching the speed control. On occassion it will work properly, does not matter if it is on automatic or not. Cleaned the in car sensors, new blower. Any ideas.
thanks for any help.
Old Jun 19, 2007 | 05:40 PM
Default RE: a/c blower
Do the A/C and recirc lights flash when you start the car?
Old Jun 20, 2007 | 02:24 PM
dumpling's Avatar
they did but that was because of an unplugged sensor. this problem was there before any work had ever been done to the a/c system. Evap replaced.
Old Jun 21, 2007 | 05:51 PM
Has the blower resistor been replaced?
Old Jun 22, 2007 | 06:56 AM
dumpling's Avatar
no, but I thought if that was bad putting it on high it would not run at a lower speed it would turn off, unless it is some kind of variable resistor, I'm not sure never looked at it.
Old Jun 23, 2007 | 07:30 AM
The resistor is only supposed to be for lower speeds but on the ECC models if to many amps are drawn the ECC module will drop the voltage some.
You could have a bad resistor.
evpridgen
May 21, 2011 04:59 PM
jmallie
Sep 17, 2009 09:47 AM
florida98s70glt
Sep 11, 2009 07:56 PM
golfrepairmanri
Oct 28, 2008 09:30 PM
woodworker
Aug 24, 2005 09:06 PM
