A/C not blowing cold
Old May 5, 2006 | 09:25 PM
ProMischiefMaker's Avatar
Default A/C not blowing cold
ok, I'm back with the next issue I'm taking on. The A/C in my '97 850 GLT isn't blowing cold at all. it's blowing a little bit colder than the air outside (in baltimore) which is about 78 degrees right now. a few shops a while back said that it was probably the A/C compressor, I think I'm going to do one of the leak tests with the dye and such. If anybody else has any good ideas about how to test it please let me know. -Sam
Old May 5, 2006 | 09:34 PM
Default RE: A/C not blowing cold
oh, and another factoid that is most likely related. when I turn the A/C on with the controls I don't hear a compressor click on, nor does the RPM change (in my eclipse the RPM's jump a tiny bit, I'm not sure if volvo's do that or not)
Old May 5, 2006 | 09:37 PM
If it is not ciming on at all check for power at the Low pressure switch.
Old May 6, 2006 | 07:56 PM
how would I check that for power? I have the voltage tester, I'm just not sure what exactly to test
Old May 7, 2006 | 10:36 AM
Just unplug the Low pressure switch in the pipe by the firewall and test both wires for power.
If you have no power at either one something inside is not working.
If you have Power outside then jump the 2 wires if the compressor kicks on then you are low on freon.
850_96
Jul 15, 2010 01:35 PM
micah360
May 28, 2008 04:14 PM
sosajoe00
Apr 29, 2008 08:00 PM
VolvoJimmy960
Jun 3, 2007 10:20 AM
Cboms40
Jan 31, 2007 06:09 PM
