A/C Problem... Binding....
Old Sep 9, 2013 | 08:03 PM
Annihilator's Avatar
Default A/C Problem... Binding....
Hi, I've had an A/C leak somewhere, most likely the evaporator, since I bought my '93 850 and have just been recharging the system every time it went low. The other day, It was on the 90's and a/c was cooling fine until I heard a pop and saw a/c oil shoot out from under the hood and smelled refrigerant. I saw some green dye kind of behind the compressor and behind the bottom most a/c hose and assumed I blew that hose.
The other day I turned it on and the a/c engaged and worked great. Charge was a bit low but cooled fine. The next day when it engaged, I heard a grinding/rubber noise from the compressor area. This is an intermittant problem that has also happened before the pop bur now it seems that its grinding & moaning more often so I leave it off.
Do you guys think my compressor is shot?
daver80
Aug 8, 2017 06:40 PM
kaizenman
Jan 6, 2011 09:41 PM
kecracing
Feb 16, 2009 06:37 PM
Diamond_D
May 16, 2008 11:12 AM
Marks 240
Nov 11, 2005 09:03 PM
