Can't find the answer!!
Old Jun 19, 2011 | 12:05 PM
clean850R's Avatar
Default Can't find the answer!!
Ok I know I came across it a while ago and now can't find it! What is the little screw looking thing on the headlight switch for? If I remember it was for headlight settings?? How does it work and what are the different settings? Thanks
Old Jun 19, 2011 | 12:49 PM
ibified's Avatar
Its to turn the daytime running lights on and off.
Old Jun 19, 2011 | 12:50 PM
Vmax's Avatar
Disable DRLs (Daytime Running Lights).
Old Jun 19, 2011 | 02:49 PM
clean850R's Avatar
Ok how does it work? How fo you disable or enable?
Old Jun 19, 2011 | 03:15 PM
ibified's Avatar
Push in the set screw and turn. One way will have them on, the other will shut them off. Not sure which is which, but it should be pretty simple to figure out.
Old Jun 19, 2011 | 04:25 PM
Some of the switches have 3 settings. Off, Headlights only, All lights on.
Old Jun 19, 2011 | 09:25 PM
clean850R's Avatar
Thanks
tdfive
Mar 5, 2011 05:01 PM
akorcovelos
Jul 14, 2008 06:41 PM
Scott6
Nov 20, 2007 10:45 AM
Coastal
Oct 4, 2007 05:22 PM
