Center Brake Light
Old Jan 15, 2011 | 06:22 PM
jholst's Avatar
Default Center Brake Light
My center brake light is working now and again. I changed the bulb, inspected the leads, used contact gel on the bulb but still have the same problem. When I used a multimeter at the leads it read 9 volts where the other two brake lights which are working read 12 volts. Any suggestions?
Old Jan 15, 2011 | 06:33 PM
ibified's Avatar
other than not posting the same question twice, id check the wires that go to the 3rd brake light for corrosion and check where the wires come into the assembly. I'd also check the plug.
Old Jan 15, 2011 | 07:36 PM
boxpin's Avatar
Where is your light? Is this a wagon? In a spoiler?
If its mounted on the trunk or lid the wires can eventually break at the pivot point.
Old Jan 15, 2011 | 07:39 PM
jholst's Avatar
It's the sedan. It's located on the dash behind the rear seats
Old Jan 15, 2011 | 07:41 PM
boxpin's Avatar
Then my thought does not apply.
Do you have a test light that you can connect to it for a few days to see if its the supply or the bulb assembly?
Old Jan 15, 2011 | 07:45 PM
jholst's Avatar
Well the problem is intermittent. I did see the bulb working today. So I know the bulb assembly is fine. When I put the multimeter right at the lead to the assembly that's where I see the low voltage so I think the problem is not with the assembly itself
Old Jan 18, 2011 | 12:43 PM
docmot's Avatar
Try creating a new ground to the frame and retest the voltage. If voltage returns to normal, you found the problem.
Old Jan 29, 2011 | 10:50 AM
jholst's Avatar
Got it...woohoo! Took off the whole assemble and found a hole in one of the leads. Took the soldering iron out ands life is good. Thank you for all your help.
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
jholst
Jan 15, 2011 02:25 PM
cody
Apr 14, 2008 08:41 PM
cody
Apr 4, 2008 03:00 PM
dtupac
Mar 1, 2007 01:02 AM
