Codes...
Old Jan 4, 2009 | 09:03 PM
Adrenalin540's Avatar
Default Codes...
So tonight I set out to erase all the codes from the system, since the timing belt broke and I had to add a new head to this engine I figured why not...so I start pulling codes. I was successful in erasing 90% of them there are a few remaining... and the most annoying thing is
Now the Service engine light is on and so is the ABS light... I went through again and tried to clear them out...NO JOY
Any Ideas?
I decided to disconnect the Battery ad give it a charge overnight to see if that has any bearing...I was thinking it may reset the ecu?
Old Jan 4, 2009 | 09:56 PM
Default RE: Codes...
Ok the trick for the Service engine light was
Key in Posn II on but not start
Plug the lead into Port A7
press the button 4 times
when the light responds with a single flash...
Press the button 1 time
Press the button 5 times
Press the button 1 time the light will begin to blink...
go turn the key off...the light is reset...
Now for the stupid ABS light...
Old Jan 4, 2009 | 10:06 PM
OK...
Got it...
If there are NO codes in A3 just get the car up to say 20 MPH and hit the brakes...the light will...Disappear...LOL
Tomorrow a new heater motor, and a new thermostat this one is stickin open, and this one is as good as new...
LOL
Old Jan 5, 2009 | 07:54 AM
Glad all is good now!!!
Old Jan 5, 2009 | 08:01 AM
Psaboic's Avatar
Sounds like you are sure having FUN............
Old Jan 5, 2009 | 12:02 PM
Yes I am, since I don't have to rely on it as a DD...don't forget I have 2, it is all good, and really these things are a blast to work on...no hidden surprises. I actually look forward to removing every single defect in the cars...that is just downright goofy...but that is the way it is...
Also helps knowing guys like you are here and monitoring, so when we really get stuck, there is someone behind us with a shovel...ready to dig us out...
You guys that contribute are a real godsend! It makes the whole process of ownership that much better...Thanks again
gabyman97596
May 14, 2007 09:52 PM
TBoone
Aug 8, 2006 12:52 AM
cranky
Aug 5, 2005 09:46 PM
pitar
Apr 2, 2005 11:37 PM
