convert turbo to normal
Old Jun 4, 2019 | 04:50 AM
thewhitegorilla's Avatar
Default convert turbo to normal
Can a turbo 850 be converted to normally aspirated and what has to be done to do it?
Old Jun 4, 2019 | 09:14 AM
turbos and NAs have different blocks (different compression ratios) so for starters you'd need to swap blocks. They also run different ECUs and I suspect they also run different wiring harnesses for the engine to account for any turbo specific sensors. Best way to do this would be by getting a donor car then moving bits over although I'm not sure why anybody would want to detune a turbo this way.
Old Jun 5, 2019 | 02:36 AM
firebirdparts's Avatar
I think it's at least worth a try to put an NA exhaust manifold on there, re-route the intake air, and change nothing else at all. There is a chance that could work, and if it did, so easy.
It's obviously possible for the turbo engine to run with intake pressure below atmospheric pressure.
Old Jun 6, 2019 | 07:43 PM
860ARE's Avatar
Why would you want to do this.
Old Jun 6, 2019 | 11:39 PM
gdog's Avatar
^ indeed; why?!
Old Jun 15, 2019 | 05:07 PM
Its really a bad idea.
Old Jun 19, 2019 | 04:13 PM
Stinky's Avatar
I wrote a book on this and I lost it all....dern computers.
I'll give you the short version. IMHO, it would never run right and you'd foul plugs because the ecm wouldn't be calibrated correctly.
There would be no cheap way to get you an intake...dif gaskets, so I assume dif head (although same tbi....based on a rockauto.com search)
Car-part.com
Ebay
Turbochargerpros.com
They all have turbos...way easier to get it running that way.
Old Jun 19, 2019 | 06:23 PM
860ARE's Avatar
I have a couple spare turbos that need rebuild if you want to buy one
Jmmcclean
Oct 6, 2013 10:09 PM
Kyle Olson
May 5, 2013 08:46 PM
Buffalobeans
Jul 2, 2011 10:04 AM
steelheaddan
Feb 20, 2011 01:51 PM
akem21
Oct 24, 2009 08:20 PM
