coolant in oil
Old Jan 26, 2009 | 06:14 PM
  #21
Default RE: coolant in oil
As long as the timing marks are pretty close and you press the cover down slowly you will be fine.
You can use lamps to press it down some then put all the screws in and work all the way around and snug them down to seat it all the way.
Old Jan 27, 2009 | 08:10 AM
  #22
850_Volvo_Dan's Avatar
SWEET! that sounds great. Thanks much for your help! I've ordered the gasket kit from FCP but will probably reuse the bolts (locktight anyone?) I'll let you know how it goes.
Daniel
1996 850 T5 Turbo Wagon
Old Jan 27, 2009 | 10:48 AM
  #23
I would do new head bolts though.
If you ever need to take it apart again there is a good chance they will break instead of coming out. They are stretch bolts.
Old Jan 28, 2009 | 07:38 PM
  #24
jareds4's Avatar
just wonderen what else to change when you have the head gasket being replaced
like the timing belt water pump and were is the cheapest place to get them
Old Jan 28, 2009 | 07:41 PM
  #25
I would replace it all. Timing belt,tensioner,idler,water pump.
You might also want to inspect the Vent box as well since it is right there.
Old Jan 28, 2009 | 07:47 PM
  #26
jareds4's Avatar
im sorry but what is the vent box
Old Jan 28, 2009 | 07:51 PM
  #27
The Vent box is part of the PCV system.
Sorry also forgot to give the site for the parts in last post.
FCPGroton.com
That is a Great site overall for parts and cheap. They offer the OEM parts cheap.
carson850
Jan 7, 2014 02:08 PM
dow1971
Jan 7, 2012 09:59 PM
no1pony
Sep 3, 2011 06:45 AM
gr8lady
Jun 4, 2009 01:29 PM
timk
Nov 16, 2007 08:33 PM
