Dripping sound behind glovebox??? 1995 850 GLT Wagon
The only fluid back there would be condensation from the A/C. The heater core is centered in the dash and could make a dripping sound if it was leaking from the pipe connection. Does it smell like antifreeze? It would not hurt to pull the under pan from the passenger knee bolster and pull back the carpet on the drivers side to check.
Also, check your radiator fluid level. If your sensor is not working and the fluid is low you could get a gurgling sound in the cabin.
kcarrol
03-05-2011 05:14 PM
kurdtpatton
09-14-2010 03:41 PM
