Egr
Old Jun 24, 2018 | 08:56 PM
Phil 850's Avatar
Default Egr
I passed my smog test yesterday, just barely. It looks like the issue is with the EGR system. What can be rebuilt? Can you rebuild the EGR valve? I need to trace the system to see what else is involved. What tests can I do to make sure things are working?
Old Jun 25, 2018 | 07:42 AM
tony1963's Avatar
It has been a long time since I worked on an EGR system since the technology today has shifted to VVT as a way to retain some exhaust gas in the cylinders.
I would change the EGR valve since most of the time they stick from age.
Old Jun 25, 2018 | 08:40 AM
Phil 850's Avatar
So far the only one I have found, at Rock Auto, was around $450.00.
Old Jun 25, 2018 | 11:04 AM
as I recall, access to the EGR serving is best done when you do the PCV since you will be removing the intake and related hoses. As to the "just barely" passing emissions, that should give you a clue as to what should be looked at. Too high on the Nxs? suggest you look for intake air leaks, clean the throttle body, idle air valve etc. Too high on the HCs? ignition tune up, clean the MAF, check the O2 sensor... If you suspect the EGR, check if you have a clogged PCV as well.
Old Jun 25, 2018 | 09:42 PM
Phil 850's Avatar
All good advice. I have 2 years before I have to do this again so I can pick one thing at a time and work on it. I don't put a lot of miles on the car and I like it so it is worth my time to fix stuff.
Cliff Whipple
Jan 5, 2022 05:51 AM
jholst
Jan 31, 2011 01:18 AM
960 rookie
Apr 2, 2010 11:47 PM
Dads850
Jul 8, 2008 05:53 PM
BorisRX
Oct 8, 2007 11:27 PM
