engine problem
Old Nov 22, 2010 | 07:20 PM
bmx4me's Avatar
Default engine problem
ok so ive had this car for a bout 2 years now. its a 94 volvo 850 turbo wagon. now, one random day i was on my way to work and my gas light was on and i had a backfire from the motor. now, i pulled over at a gas station put gas in and then went on my way. upon pulling out of station the car would not accelerate, it sputtered and shot alot of black smoke out exhaust. i pulled over, and it died. i can get it to start but it idles rough, runs like crap and the second i put it in gear it would die. i towed it home, and heres what ive done. i have replaced my mass air flow sensor. my plugs and wires. fuel pump relay, my cat on the exhaust. i even added some fuel injecotr cleaner thinking maybe it sucked some crap up. i replaced the fuel filter as well. still no luck. it idles smoother and will run and drive, but still really crappy acceleration and it has a hard time shifting gears, i have only driven it in my neighborhood as well since the innceident. i know my fuel pump is fine couse it hums like a brand new opne, i bought one and hooked it up it sounded the same. so please someone help me with this, what could my problem be. now after all the work and parts ive done it vcomes down to this. i start, it idles fine, almost better then before, i put in gear it sounds fine still, but once i go to accelerate it just feels like no power, almost like i have a 50cc dirtbike motor in there nmoving this car. so please help
Old Nov 22, 2010 | 07:28 PM
Have you pulled the codes yet?
Maybe ECT maybe throttle position sensor.
Old Nov 22, 2010 | 07:38 PM
bmx4me's Avatar
no i didnt pull any codes. i figured if check engine light isnt on no codes will show up?, am i wrong. ive heard someone mention the sensor that sits on my tranny, i forgot whats it called but would know if someone said it.
gilber33's Avatar
rpm sensor
Old Nov 22, 2010 | 07:40 PM
Well the crank sensor(speed) sensor is between the tranny and engine and reads the flywheel.
You might have codes there. If you can read them I would. Are you sure your light is not burn't out?
Old Nov 22, 2010 | 09:09 PM
bmx4me's Avatar
yea im sure. it was one until i did all the replacement parts. now its not on, just runs like crap
Old Nov 22, 2010 | 09:11 PM
bmx4me's Avatar
and how sure are you on the rpm sensor. i dont want to seem like a dick but im just tired of buying parts i dont need. so therefore i am simply asking
Old Nov 22, 2010 | 09:25 PM
Me I would look other places first. The black smoke is a sign to me that something is making it run to rich.
Have you checked all the intercooler hoses good for cracks or holes? Make sure one did not blow off.
If you have OBDII see if you can get your hands on a scanner that can read real time. The read the O2 sensor and ECT temps.
Old Nov 23, 2010 | 07:04 AM
Rickford's Avatar
94's only have OBD under the pass side hood in the front. Not every problem will triger a light but can still set a code. You said the CEL was on but now off? Who cleared it, they do not clear by themselves?
Old Nov 23, 2010 | 09:00 PM
Some 94's have OBDII as well. Just a FYI.
Old Nov 24, 2010 | 05:36 AM
Rickford's Avatar
Wow, I stand corrected, thanks! It's just that I have never come accross anything that indicated that. Always something new to learn...
Old Nov 24, 2010 | 07:57 PM
I just learned this like a year or so ago myself.
Old Nov 24, 2010 | 11:15 PM
bmx4me's Avatar
ok i bought a chiltons manual. nowhere does it say rpm or speed sensor. heres my latest update. with transmission in "park", i can rev the engine up and hit the governor or whatever. with it in drive it will not go over 2000 rpm, in forward or reverse. if i put it in neutral, i can rev it jsut fine. any thoughts to whats going on.
Old Nov 25, 2010 | 01:07 AM
gdog's Avatar
Did you ck the fuel pressure at the rail?
Old Nov 26, 2010 | 12:15 PM
91shelby's Avatar
hows the catalytic converter? check for any major air leaks in the induction system say around the MAF sensor
Old Nov 26, 2010 | 05:24 PM
bmx4me's Avatar
the fule rail has pressure, its a brand new cat, but no luck. its gotta be a sensor or something small.
Old Nov 26, 2010 | 05:36 PM
  #17
91shelby's Avatar
o2 or TPS possibly
Old Nov 27, 2010 | 12:55 PM
  #18
Rickford's Avatar
Hay, how about the codes? I don't see that you pulled any or at least confirmed there were no codes, either OBD or OBDII which ever one you have? Are there any codes? Just wondering....
Old Nov 28, 2010 | 09:11 PM
  #19
davis3903's Avatar
Default possible answer
distributor cap crack could have built up moisture so the sparks cross fire
it has happened to me from rinsing the engine off or hitting a good size puddle.
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
